Multicast group join error.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to join Multicast group. Sockets error code = %p1% Multicast group address = %p2% Socket ID = %p3% Socket type = %p4% Socket family = %p5% Socket protocol = %p6% Application handle = %p7% Stub socket handle = %p8%
| Name | Type |
| p1 | sInt |
| p2 | VarFmtByteArray |
| p3 | sInt |
| p4 | xInt32 |
| p5 | xInt32 |
| p6 | xInt32 |
| p7 | uInt32 |
| p8 | uInt32 |
